Dashcam wiring to fusebox, Which Fuse Numbers, '24 Laramie
thomasglarsen
Chicago Area
Hemi V8
I have a Viofo A329 dashcam and wish to tap into my 2024 Ram 1500 Laramie fusebox so can use the dashcam's parking feature. I will need a constant power fuse and a auxillary powered fuse. Which specific fuse numbers should I tap into? There is a wire from the dashcam for constant power, a wire for auxillary power and of course a ground that will be connected to a bolt. Has anyone done this? If so, what fuse numbers did you tap into? Thx in advance. Tom
Burla
2010 Hemi Reg Cab 4x4
I would get a dedicated rechargeable battery pack, mise well use both lines in it. Just giving you an option. Gotta love teslas having 24/7 monitoring, but they have a battery that can handle just about anything.
Burla
I guess they have an motion activated which can save it, but anyone with a motion activated anything can have any types of events run endless video snaps.
Yes, a Viofo A329 dashcam, especially when used with parking mode and a hardwire kit, can potentially drain your car battery if not configured properly. However, this is not a guaranteed outcome and can be prevented with careful setup and monitoring
From this reddit post...
Viofo Draining Car Battery - What am I doing wrong?​
Reddit · r/Dashcam
10+ comments · 5 months ago
Viofo A129 Plus Duo with the 256 microSD. Hardwired to my Toyota hybrid battery (by the dealership) and has drained my car battery twice.
