Death wobble
allenw88
Aurora, Colorado
So today as I was driving to work, my truck started shaking insanely crazy... I let off the gas and slowed down quite a bit and it finally straightened out... Could this be a steering stabilizer problem perhaps or something a bit more into it..... Thanks.
Sent from my SM-N910V using Tapatalk
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
A steering stabilizer helps keep everything in check but will never be the direct cause of death wobble. A properly built and tuned suspension shouldn't even need a steering stabilizer when it comes to that.
It's likely that something is worn out causing the issue. The first thing to check is the track bar bushings. From there I'd check the tie rod ends and drag link.
allenw88
allenw88
Aurora, Colorado
Ok thanks... I'll look into that... Good thing I'm working at orielly I guess.. Lol
hdwrenchtx
TX
I had that happen to me in my work truck. It was a broken belt in a tire
RJL1
Jersey Shore-By the beach
I've had it and the dealership replaced the steering stabilizer on my '12. Hasn't come back.
