Debadge Etc.
AKreed22
AZ
4.7 v8
Just wanting opinions on what works best to get the foam and glue behind emblums and window rain gaurds that are left behind on the paint. Want to make sure i dont scratch the clear!
reefguy89
laurel de
an eraser wheel is by far the easiest. goo gone works good to. Just apply it then let it sit on there for a little bit. THen peel off. Its alot of work but it gets the job done.
blackout11
alpharetts GA
2011 R/T
yep goo be gone spray on let it soak and use your fingers to get off works great
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Eraser wheel ftw
tapatalkin'
4XLGATOR
CTD
I actually used both...eraser wheel and goo gone. Then I used Meguiar's Scratch-X 2.0 to remove the ghosting. DON'T go crazy with the Meguiar's Scratch-X...meaning don't work it too hard.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I used 3m adhesive remover and the front of my fingers. Painful, but short and no scratching.
bigbadram1500
Springfield, IL
I started with goo gone, but after I couldn't feel my fingertips anymore, I used an eraser wheel and the glue/foam was gone in seconds. :)
05singlecabHEMI
Lilburn,GA
I used goo gone. Came off like a champ. Just some dirt that couldnt be wiped off left over and i used a clay bar to get rid of that.
HemiBabe
DFW
I used fishin line to get off the badges and door spears and bought trim adhesive remover from oreillys and it came off nicely
A
AKreed22
AZ
4.7 v8
Nice thanks for the info, just didnt want to mess up the paint at all
