DEF/DPF Delete with no tune
jwilliams3527
Birmingham, AL
Cummins 6.7
I need some help. I recently bought a 16 2500 that was advertised as "deleted and tuned". Being relatively new to the diesel world, I just looked to see if the DPF had been removed and if it was requiring DEF. There was no tuner included, so I can't be sure about the tuned claim. However I recently noticed that the EGR system is all there and all the plugs are plugged in. I don't get any codes except for the grid heater which I disconnected until I get time to install the delete. My question is, is it possible to do a DPF/DEF delete without a tuner and not have the engine throw codes or go in to limp mode? I'd like to do an EGR delete but from what I've read you need to have a tune for it to run correctly. I have an easy lynk , just haven't installed it yet. Just curious as to how it's running fine and have no codes with apparently no tune.
nlambert182
Huntsville, AL
Nope. Not possible.
Was the DPF still there? If yes, it's not deleted or tuned. If no, then it's deleted and is running some sort of tune.
You "can" turn off the EGR valve and throttle valve while leaving them plugged in, but it would require a tune. You also have to remove the DPF regardless. You don't "need" a physical tuner for it to be tuned. They could have tuned it and kept the hardware.
Tell me more about the truck. 2500? 3500? Just curious. I sold my 2016 3500 a couple years back. Been looking for it ever since.
J
jwilliams3527
Birmingham, AL
Cummins 6.7
My truck is a white 2500 SLT, leveled with 35s that came from South Carolina. Had 175k on it when I bought it. Actuator failed 6 weeks after purchase so I just replaced the whole unit with a Fleece Cheetah.
The DPF is not there, race pipe installed and DEF gauge stays pegged at full.
Is it possible for me to test the EGR system? For example, unplug the EGR and throttle valve to see if it throws codes, or doesn't run right?
Will it go in to limp mode?
nlambert182
Huntsville, AL
ahh ok.. definitely not mine.
If the DPF is missing, it's tuned. Just unplug both and see what happens. Chances are, they took the easy way out and didn't pull anything off.
nlambert182
Huntsville, AL
It won't run ok with the sensors plugged in if anything was physically removed from the truck unless it's tuned. The sensors will give inaccurate readings and will trigger a code in the ECM and start the countdown. If you delete any of the emissions components, you MUST tune the truck. It doesn't matter if you physically leave the components in place or not.
Bruce F
Woodstock, IL
What do I need to do to tune the truck, if the parts are not removed?
Are there decent inexpensive tuners that are available?
Does anyone know where these can be bought?
This is for off road use only...
mtnrider
Georgia
Has anyone used this EZ Lynk Auto Agent 3 Tuner?
Yes, its a great tuner.... But it's just the hardware for loading the tune, you still need to purchase the tunes from a tuner. You will have to look to Canada to find tunes and beware, there are a Lot of fly by night hacks out there selling tunes.
As far as expense, you are probably looking at around ~$1600+ to do it yourself, more if you are paying someone
nlambert182
Huntsville, AL
The DPF has to come off either way though... It will clog if it can't regen.
alphaprojects
