Sybil
- Jul 7, 2013
- 1,153
- 394
- 2011
- 5.7 hemi
Thank God for the internet!! By the way they shorted me one of the brass nipples and of course no one had one....
From your pic it looks like you have all you need. Two brass fittings on the can and one for the throttle body. The long hose attaches to the PCV valve without a brass fitting.
The Diablo catch can is actually made by Billet Tech, and they just put the Diablo logo on there for them. It does not require the 2nd barbed fitting to attach the new line to the PCV valve, but BT puts it there anyways because a few people complained that they had trouble removing the factory line from the PCV valve...mine did not need the 2nd barbed fitting to make this connection.
It does, but on your truck you have a high mount location and a low mount location. I like mine sitting in the lower one. The upper one like in the video you watch you have to remove the wire harness plug before install.
From that hole if you drop down 4" and it's at 7 o'clock. Gravity helps pull what Evers in the line down to the can this way.
