It's billed as stronger and lighter, but I am sure there are dollar signs to be found in that equation. Ford is using it on the powerjoke, and Gimmick Motors on the duradud, but GM just announced a buyback of L5P duraduds for blocks that were apparently improperly heat treated, which can lead to head gasket failure, and hydrolocking. They are buying the trucks back in lieu of doing engine swaps.I read up on CGI. It's just a halfway cast iron in between grey and nodular (ductile). I suppose it's halfway priced also.
The Ram version of the 6.7 is unique, as it is the only version with the timing case at the front. I was told by a Cummins rep at a trade show that the Ram version is the only one currently using the CGI block, as well.
