Differential issues
skirider
2011 ram 1500 4x4. 3.55 axle ratio
Long story shorr something whinning bad in rear diff
45000 miles on truck. Is this possible pinion bearing shot?
What size diff do i have?
And i also have no fill in cover
Should i replace cover with updated?
Also i had pinion nut recall done about 30000. I wonder if they messed it up
Also saw a recall about low fluid but my truck suposibly was not on that recall.
Lots of questions. Main being how could this be at 44000 and i baby this truck
SETEX 6.4
Port Neches, TX
My guess is yes absolutely the ********* at the stealership could have overtightened the new pinion nut causing to much pinion bearing preload.
The reason I say this is because it has happened to me twice.
The first time was on the rear axle of my 2014 2500 that the pinion seal started leaking and I had it fixed under warranty. Needless to say they over tighten the pinion nut and caused a wine in the rear end. In the end RAM replaced my whole axle assembly.
Second time it happened on the front of one of our 3500 work trucks. Brought the truck in because the front pinion seal was leaking. They also over tighten that pinion nut and caused the pinion bearings to wear out. I would not let them fix that one because it was not under warranty any longer they refunded my money and I brought it to a local differential shop and had them rebuild the front differential.
I don't want to be a Debbie Downer just letting you know what has happened to me in the past with Pinon nuts.
2014 Ram 2500 Mega Cab 6.4 Hemi 4:10 Gears Ram Boxes 35x12.50R18 on Factory Wheels
Sent from my SAMSUNG-SM-G891A using Tapatalk
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
The dealership did the same to me on my old truck. Over tightened the nut and caused the pinion bearing to fail at 22k.
S
skirider
Ok. Do i have the 9.25 size re end
Looking for parts
Are timiken bearings good
I more ok with a dealer mess up thsn just a failure i guess.
If that makes sense
I wonder what the chances are of getting this covered by dealer. Probs slim to none
SETEX 6.4
Port Neches, TX
Go back to them and tell them you think they overtightened the pinion nut and what can they do to make it right.
Start there.
huntergreen
I thought all 11s were subject to the low fill recall.
S
skirider
Im confused on the low fill. How do you overfill past fill plug?
If thats how im reading low fill
Looking for parts
If that makes sense
Being a 2011 you should have the 235mm ZF rear end. The earlier AAM diff is the one generally referred to as the 9.25 diff.
S
skirider
Ok when i go on rock auto to order diff kit. They have listed as 9.25 or 8 or 12 something
S
skirider
Ok just going to go oem.
Bot much price difference
Whats up with rear cover
Mine has no hole
Should i update and or just fill from plug in housing
Mine has no hole
Fill and drain from the 2 plugs on the front side of the diff.The hole in the cover I think started around the late 2012's early 2013s,before that the fill hole was in the housing itself.
S
skirider
Ok thanks. Ordering parts snd plan on tackling this weekend
Anyone got a good online oem parts site.
Free shipping and or discount
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
I usually get p/n from places like mymoparparts & plug p/n in at rockauto.
Compare prices & order from 1 or the other.
