distribution block help
loman21
hey guys looking for some help on a swap that I might have to perform. I have a 1997 ram 1500 5.2l automatic 4x4 that was purchased with the fuse box under the hood burnt up. the only one that I have slightly available is out of a 2002 ram 1500 with what I believe is a 5.9l. my question is has anyone ever done this swap and if so I would like to hear about how it went and what all needs to be modified to fit. thanks in advance
SYKRAMMAN
Banned
Jersey shore
06 Mega
Go to Automix.com they have everything and if not then they will find one for you for cheap, very cheap. The 02 fuse Box has a bcm on the side of it so I don't think it'll work even with major modifications. The 02's need programming when replaced to. Hope this helps a little, good luck bud, keep us posted.
jlbayes
2001 & 1997
5.9l cummins
No that fuse box/pdc will not work in the 97. You need a fuse box/pdc from a 96-97. Ideally out of a 97.
