Distributor gear
vtdodgeboy
5.2 Magnum
I just did a cam swap into my 360 magnum and i have it mostly back together. One thing i forgot to do was line up the distributor gear/oil pump shaft with the number one cylinder. its close after installing the everything can i just adjust the time to make up for the difference or do i need to pull up the gear and rotate it till it lines up with the number one cylinder.
Merc225hp
NA
truck
gas
You need to pull the gear and turn it to where it needs to be.
