Dodge ram 2500 gasser
nash ranch
Springfield Oregon
6.4 L hemi
Thinking buying a dodge ram 6.4l gasser. It had a po 871 code. Should i be concerned about this code??
rzr6-4
nebraska
'09 2500
Any potential problem can be fixed for the right amount. If the rest of the truck is in good shape and its priced to give you room for potential issues then go nuts. If its already overpriced then obvious the risk isn't worth it. No way we can judge from the info given.
Ritchie_Rich
Law Enforcement
NV
No way to tell with the limited info given.
Personally, I wouldn’t purchase a vehicle that exhibits codes.
mtnrider
Georgia
You should be concerned about any code. I'd never buy a vehicle that has a check engine light on. If it was an easy fix the owner/dealer would have fixed it. THey will try to pass it off as simple part to replace.
N
nash ranch
Springfield Oregon
6.4 L hemi
Thanks Red.. this truck is a beauty but had 171,000 on it with a po871 code. They want 17,500 for it. Not sure i want to do this
Code P0871 indicates a "Transmission Fluid Pressure Sensor/Switch C Circuit Range/Performance"
Factor in you may need to have the transmission rebuilt.
N
nash ranch
Springfield Oregon
6.4 L hemi
Thanks for that tranny info.. the gal selling this truck is not very responsive when i Ask questions about the po871 code
N
nash ranch
Springfield Oregon
6.4 L hemi
Finally heard back from the gal selling this truck. She says it needs a new transmission or so she was told. Glad i didnt buy it
Docwagon1776
Midwest
So what tranny is in this 2015 6.4l gasser?
The garbage one. IMO, it's worth the money to go for 2019+ to get the ZF 8 speed. Its a better driving experience and it's significantly more durable. In half tons the 6 speed is fine, but drive an HD back to back with each and you'll throw rocks at the 6 speed one.
Ghstrdr95
