Double din installed in 2013 express
smiley87
Alaska
5.7l hemi
Got my wiring harness and dash kit yesterday and installed my Kenwood
Sent from my SCH-I535 using Tapatalk 2
Etroze86
Grand Forks ND
I like the install but WhiteExpress is right there is just something that puts me off on it. I think its the buttons on the screen and rounded area of the dash. Good job, are you doing anything else for stereo?
S
smiley87
Alaska
5.7l hemi
Probably gonna add a 10" sub under back seat but that's later on. It sounds pretty good so far
Caldwell
Philadelphia
how much did everything cost you ?
Im looking into a Single Din Alpine HU w/ Alpine Speakers at the moment...
Podcast
Da sticks
Nice. I can't do that. My climate controls are built into my 8.4A.
S
smiley87
Alaska
5.7l hemi
Came out to 115 for harness, 10 for dash kit, and 5 for antenna adapter. So 130 total.
SCMortgageMan
SC
5.7 Hemi V8
What factory setup did you have...5.0 Uconnect or ?
Just curious b/c I have the Uconnect 5.0 and wanted to see about swapping with something better.
PX8
2013 Express Crew Cab
so true, so true.....
Boilerlife
I want to swap mine out but I have the 5.0 and the radio controls some of the trucks functions. Would I really be losing anything if I swapped it out? I'd love to have the larger screen with navigation and backup camera!
SCMortgageMan
SC
5.7 Hemi V8
What Kenwood unit is that and do you mind sharing the part #'s for the adapter, harness, and kit?
S
smiley87
Alaska
5.7l hemi
Metra website has all the numbers. If I remember correctly the harness number is part # XSVI-5523-NAV
My kenwood is a ddx719. Couple years old but I like it
detwallace
Kentucky
Smiley,
Just to be clear, this wiring harness allows for navigation and back-up camera functionality, correct? Did you install a back-up camera? I thought i found harness # XSVI-6523-NAV for this, but I'll have to go back and check. Obviously yours is working so...
Thanks for taking the time to help. I despise my 3.0. The Philco radio in my old 65 Ford was at least equal to this one.
S
smiley87
Alaska
5.7l hemi
Smiley,
It may be that number. I had the factory camera in the mirror. the harness has the reverse input signal and an rca for backup camera but the rca didn't work so I tapped into wires going to mirror. I think the rca works if you have the 5.0 stereo though. Don't remember if it had a VSS (speed sensor wire) and my kenwood isn't nav so I didn't need it either way I use google maps on my phone
Trinfo3000
V6
How do you tap into the camera wire to make it work on the radio from the rear view mirror display?.
Thanks
operator
Professional Firefighter Captain
Marrero, La
so did you have to do any dash cutting to install this? I want a double din but if I have to cut my dash im just gonna get a single din flip out screen there are a couple 8.4 flip outs I like
jbr
Long Island, NY
I would also like to have a larger screen but I have the 5.0. I can't find any information about aftermarket head units and maintaining all current radio/computer controls.
Sent from my DROID RAZR HD using Tapatalk
jbr
Long Island, NY
You lose most of uConnect functions. You have to set them the way you want before you remove your stock head unit.
powderbrad
Edmonton, AB
Something about the design doesn't strike me as tie-ing everything in nicely.
Don't get me know it looks good....but doesn't strike me as awesome looking / smooth / clean, The work you did looks good, dodges design however....
