Dr door switch
Bog8r
I need to replace the window switch on the driver side door, can I remove the switch without removing the door panel? Or do I need to remove the door panel to get the switch out?
Thank you.
HemiBabe
DFW
You can use a flat head screwdriver and gently pry up on the outer part of the switch bezel and it will pop right out :)
Deviate
St. Augustine, FL
2005 4x2
Gently is the key word there. The little plastic pieces that hold the trim plate in place break off very easily. I only have 3 left on my driver door. I had to fashion up a bracket out of aluminum to hold it all in place. Which works very well by the way.
B
Bog8r
Thanks again for your help.
