Texastruck
I had an alignment done at the dealership and the steering wheel was off center when completed on my 2019 2500 4×4. So its easy enough to adjust the drag link so I centered the steering wheel but the bolt for the clamp on the drag link (new style for 2019/2020) was on too tight and slightly bent. I picked up a new clamp bolt from dealer and installed. I torqued it to 50 ft lbs which is the recommended torque for a 7/16 grade 8 bolt and it shows a slight bend also. This may be normal because of the angle of the holes in the clamp or did I also over tighten? If this bolt breaks/loosens I would loose all steering. Any insight would be appreciated.
