DRLs
RamKing70
Lockport NY
Hey fam... I have a 2016 express and I'm playing around with alfaob. I was trying to enable the DRLs. I have the option turned on but they do not come on. Other then wheels and tires my truck is stock. Does anyone know if I need to change anything in the harness or should they have worked? I know I'm connected correctly because I can access and change other settings with it. Thanx!
Right from known working list:
DRLs: (Daytime Running Lights) For “Dedicated” DRLs (Rams with factory projectors) see post #7079
https://www.ramforum.com/posts/2032174/
CBC Features: DRL Configuration
Select “Optional DRL”
CBC Features: DRL Lamp location (several to choose from, high beam, low beam, fog lamp, dedicated and SRT Light Bar) Known working high beam, low beam, turn signal and fog lamp.
CBC Features: DRL Dropout Enabled
Select “yes”
ECU 3: DRL Customer Setting Enable/Disable
Select “yes”
Customer Service Menus: Daytime Running Lights CSM
Select “yes”
Don't enable DRL dropout if your using the Lows or Highs as the DRLs
The DRLs only work if the truck is in gear and the parking brake is not set.
big daddys house
Hill Valley
Follow this and you will be good to go brother.....
You may have to take it for a drive or cycle the truck a few times but it will work.
Sent from my LG-LS995 using Tapatalk
R
RamKing70
Lockport NY
Select “yes”
Select “yes”
Select “yes”
I don't have factory projectors...
I'll check it out
The only difference in the set up is you can't use the dedicated outputs.
For those you would have to add the wiring to the harness under the fuse block. You can get the wiring pigtails from M² Mods
PIN 8 - LEFT DRL LAMP DRIVER
PIN 23 - RIGHT DRL LAMP DRIVER
My truck came with Quads from the factory and added the dedicated circuits.
R
RamKing70
Lockport NY
Select “yes”
Select “yes”
Select “yes”
WORKED LIKE A CHARM! Much love!
joshhhh
