Drop brackets and Resi's
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Ok guys here is the latest addition of upgrades.
I had the maxtrac kit 7" lift kit with bilstein shocks on. I've since upgraded the 5 link system to Core 4x4. I had purchased the pro-comp rear box lift kit that included the rear control arm drop brackets I wanted but had these suckers almost a year before installing them.
I replaced the shocks with Bilstein 5165's adding the reservoir's with upgraded clamps and added the pro-comp drop brackets to the install. Needless to say nothing goes as planned and it took me all day to get the parts installed.
JB1
Houston, Texas
Yes that’s a lot of work, I bet it rides great now.
RedSRT4Me
RedSRT4Me
Scottsdale, Az
2015 CC Sport
It sure does. Now I need to pay attention to the front.
Still looking to make a 2wd coilover kit.
So far the LCA's from a 4x4 will be the easiest way. Dirt king has upper shock mounts that need to be welded in. Then just need to spec the coilovers. Off the shelf won't work because the DK upper mount is just an eyelet but they'll know which coilovers I'll need.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
That is what I am interested in , 2wd coilovers ... when you are done please show them off ...are you doing all this yourself ?
RedSRT4Me
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Sadly no. I'll need to source a fabricator once I've collected all the parts to weld in the new upper coilover mount.
2018 2wd
Any progress on the 2wd coilover kit conversion ?
RedSRT4Me
RedSRT4Me
Scottsdale, Az
2015 CC Sport
It's shelved for now. Truck is paid off so when the shocks fail on the front again the Dirt king long travel kit might take its place. I need to find someone with a set of those coilovers on their 4x4 to see if the money will be worth it.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I was under the impression the jonny joint was more beneficial on the axle side and not the frame side
2018 2wd
DK is just down the street from me .... Might have to save some money to check it for myself sometime next year ...
Hawaii_Built
Hawaii
ecodiesel
What is the advantage of the pro comp rear vs. BDS/zone rear setup?
aimcgma
