Drop in filter??
pajeepman
SE PA
5.9 magnum
Looking at getting a drop in replacement filter for my '03 5.9 1500. Same filter as the 4.7 and Hemi use. So far I have found the K&N and spectre. They look the same, both oiled filters with the spectre being ~$15 cheaper. Any other options or opinions. I have run K&Ns in my Jeeps and Mustang for 20 years.
R.L.K.
Bristol , Tn.
I have the dry spectre , from Advance Auto parts, I like it , I think it has the better seal which is one other the things I look for in a quality filter .
justin13703
MD
I stay away from oiled filters. Dryflow is a better option
pajeepman
pajeepman
SE PA
5.9 magnum
The only spectre one I can find is oiled like a K&N. Do you have the part #?
R.L.K.
Bristol , Tn.
Give me a few mins , I'll send you a picture of the box .
Pictures as promised , Hope this helps !
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
In my 4th gen I have AEM dry filter. Not sure if it would fit in 3rd or if it would be different one.
pajeepman
pajeepman
SE PA
5.9 magnum
R.L.K., that is an oiled filter, I was looking at that at Pep Boys last night.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Works great been using is for a few years and is dry no oil needed. Just clean with AEM spray, wash, let dry and then put it back in.
R.L.K.
Bristol , Tn.
I stand corrected , it is preoiled @ the factory !
R.L.K.
Bristol , Tn.
Great fit with a realy good seal .
Crazy thing is , I've put in two of these (about every 10k) I've never noticed any literature on it being oiled . It doesn't feel or look oiled , just looks like dry red filter media . I've ran oiled filters in the past on atvs , motorcycles and vehicles . We use oiled filters at work as well , I never would've known thisone was oiled if you hadn't said so . I Googled the p/n and one of the discriptions said " Preoiled @Factory " that's the only place I've seen any reference to it being oiled ... Thank you sir for pointing that out .
