lizardking
- Sep 22, 2013
- 373
- 35
- 2014 Ram 2500 Laramie
- Cummins 6.7 "The real deal"
You would use the GEQ to flatten out the factory equalization which you don't have since you don't have the Alpine. There may be some EQing going on from the base head unit. You can just use the PEQ.
You can't measure your way to sound quality you must listen your way there. I would use the EQ to flatten out peaks and follow the base curve from JBL without adding so much bass. I think Andy did it that way because most customers want over powering bass rather than true SQ. Your bass should never be over powering and a good set of headphones listening to your favorite tune will confirm that.
