Dust covers going over Aftermarket Led headlight bulbs
Ronaldw
Does anyone know if your dust cap will go back over an aftermarket Led headlight (high beam bulb) once installed? The lasfit mini led bulb to be exact. Thanks
misfit77
Those might be a bit high.
Theres a vendor that i bought , after years if buying cheapos with flexible heat sinks. They fit fine.
Sorry cant think of brand...ill check when i get home.
BOWERSFJ
Uniontown OH
Caps fit on from Cougar Motor 3.0’s
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Sealight x2 will fit low and high. s2 will only fit lows. Can't recommend them for highs as the 9005 requires a different clocking in our truck and the collar doesn't have the additional hole to clock correctly.
Sent from my SM-T500 using Tapatalk
R
Ronaldw
Does anyone have experience with the lc plus series from lasfit?
