Clatech
Hello, new here so bare with me on this one. Did a hemi swap with a 2005 1500 5.7, 545rfe trans to my classic truck. Used the stock wiring harness and ECM. Motor runs awesome but the trans is stuck in limp mode. The ECM is not seeing the trans for some reason. The sensors such as temp and pressure show up on the scanner but have no values. I can disconnect them and do not get any fail codes. I tried a replacement ECM and same problem. Anybody have any ideas to try on this.
Thanks
Thanks
