Ecodiesel delete issues
kbmc
Mississippi
ecodiesel
I had a complete delete done on my 2017 ecodiesel and it ran great for about 2 weeks. Gained 4 to 5 mpg. Then it lost power and smoked on occasion. I would stop for a minute and it would clear up. Now it does nothing but idle. It wil not run over 1200 rpm no matter how hard you press the pedal and 3 mph is top speed. Even then it dies frequently. It smokes like a tractor. Would anyone happen to have any idea? I have heard it was a cheap tuner used by the guy who did the delete says he used a GDP (?) tuner and claims they are thought to be the best. I'm in a mess.
HuskerRam
Air Force
Tucson, AZ
3.0 Ecodiesel
Check all your plates/connections to make sure nothing came loose or broke away. Kinda sounds like one of the charge pipes (to or from the turbo) may have popped off and you're not building pressure. Not likely the tune since it was running good until recently.
Dgon
Bryansk
Hello everyone. I need help. My EcoDiesel 3.0 V6 engine is jammed, they tell me that there is no point in repairing it. They suggest installing a Jeep Grand Cherokee engine. When inspecting the unit, differences in the mounts and attachments were revealed. Has anyone encountered such a replacement? Or should I look for a RAM engine for my ram?
