Edge torque converter question
Corbanrhoads
Pampa Tx
Am I able to use an edge torque converter on my 2013 ram express? I can't figure out which transmission it has
BlackRamHemi
Edmonton Alberta Canada
simplest way to ID an 8 speed transmission ...the shift selector is a dash mounted knob
You have to know which trans you have first, 6 speed is fine,
The new ZF 8 Speed has a specialized twin torsional damper system
that controls various couplings via the PCM/TCM.
It will be a long time, if ever, that you can get an aftermarket TC for an 8 speed.
The torque converters which are produced at ZF's location in Schweinfurt, play a major role when it comes to the quality of the 8-speed automatic transmission. Owing to the latest torsional vibration damper technology, converter slip can be bridged at a very early stage already without compromising comfort – this increases the transmission's efficiency and reduces consumption. The advantages of the 8HP convince more and more automotive manufacturers worldwide: ZF is currently building a transmission plant in Greenville/South Carolina, USA, to fulfill a supply and license agreement with Chrysler.
C
Corbanrhoads
Pampa Tx
Thank you!! Great information!! I just found out the 2013 ram express is only available in the 6 speed
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Yers, only '14's have the optional 8 speed.
sinister856
Millville Nj
2013 1500 express
Does anyone know how well the factory 6 speed auto trans on my 2013 1500 express will hold up with the new procharger kit?
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
It won't
Etroze86
Grand Forks ND
Buy an upgraded transmission and learn how to rebuild them on a bench.
Lhemi
OKC OK
I think his original question is, which transmission does he have? The 45 55 65 66 68? And how do you tell them apart?
Graygoose
Oklahoma
Convert, for now.
small
Six speed, so should be 65RFE
