EGR on 6.7 Cummins
moparguy62
CT
6.7 cummings
Has anyone had any luck doing just a EGR delete on a 2019 6.7 cummins? I had a 2012 fully deleted but prefer to not go that way again.
Dennis Shellito
Ft. Morgan, CO
Cummins IBS
If you are not deleting the DPF I would advise to just leave the truck stock. The DPF seems to be where the emissions fail the most.
mtnrider
Georgia
There are some tuners that offer "emission intact" tuning that disables it (and leaves the DPF). However that seems to cause issues with the DPF after time. If you feel you have to delete for what ever reason you are probably better off going all the way.
MarcosnsBrasil
Brasil
Cummins 6.7
[QUOTE = "mtnrider, post: 2309250, member: 26842"] Existem alguns sintonizadores que oferecem sintonia de "emissão intacta" que a desativa (e deixa o DPF). No entanto, isso parece causar problemas com o DPF depois do tempo. Se você sentir que precisa deletar por qualquer motivo, provavelmente é melhor ir até o fim.
.[/CITAR]
Friend, do you know anything that I can disable DPF for Ram 6.7 2020?
moparguy62
moparguy62
CT
6.7 cummings
I did do a EZ Lynk tuner, but seen EGR does soot the intake i was hope n to delete it. I also had issues towing with EZ lynk in 60 HP gain threw codes for egr and turbo boost.
chri5k
USA
Diesel
.[/CITAR]
You can really can't 'disable' the DPF. It is essentially a mechanical filter that traps partially burned fuel or particles. When it becomes clogged, the truck must perform a regeneration cycle to burn off all those accumulated particles. If a tuner disabled the regeneration cycle, the DPF will become severely clogged in pretty short order. The only choice is to delete it. The EGR can be disabled by emissions intact tuning. However, this will result in higher NOx production which then works the SCR harder and uses more DEF. Many tuners note that emissions intact tuning will shorten the life of the SCR.
MarcosnsBrasil
Brasil
Cummins 6.7
Yes I understand!
But I would like to do so.
I want a complete exhaust and also turn off the speed limiter.
MarcosnsBrasil
Brasil
Cummins 6.7
I thought about EZ Link, but I hadn't spoken to anyone I had already done!
MarcosnsBrasil
Brasil
Cummins 6.7
Yes I understand!
