Eibach install
Finchr
Finally completed by Eibach install with 4 new springs and struts/shocks. Replaced any suspension part that had to be removed in the process. Using only hand tools this job took me close to 2.5 days. I think I spent 8 hrs just getting the old strut nuts off. Used a Shankly spring compressor and it did great! I took all center of hub to fender before/after measurements, but can’t find my notes . End result is 40.5” rear and 39” front ground to fender.
Overall, I’m happy. The kit was under $600 shipped and I knew I wasn’t in the market for bigger tires any time soon. Told my wife I’m not sure the effort was worth the result lol. Still looks like it could be stock to me. ‍♂️
Socalramfan
Huntington Beach
2011 Big Horn
I think that’s because it’s harder to see the difference with stock wheel/ tires set, and the color of the wheel wells vs tire. Just a lighting issue. Looking close enough you can see the larger opening afterwards :waytogo:
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
By any chance did you snap a picture of the strut top nut? in my experience the strut compressor you used is really hard to get the eibach coil to compress for a proper installation. Leading to a bird chirp squeak in about 2-4 weeks
F
Finchr
Dang, no I didn’t. Hope that doesn’t happen…
F
Finchr
How many threads were exposed past the nylon lock nut
Oh a lot, maybe 3/4” or more? I really had to compress the spring to be sure it was tightening down on the shaft properly. After it was tight I compressed the spring just a little bit more to be sure. If anything, I would have erred by over compressing the spring.
olyelr
Kewadin MI
Looks good
Whats the story behind the sawed off monkey wrench ?
Everyone cuts wrenches ;) its part of the process.
Thuren builds a neat upper shock mount set-up Ian.Comes with a stubby little wrench and a couple captured nuts to replace the factory nuts.
Wes Veness
Winnipeg, Manitoba, Canada
2019 SLT Classic
Looks good!!! Can totally tell it's raised.
lazer
hemi5.7
Looks a lot better, I like these trucks when they are level. My truck I lowered the back to get it level.
