ELECTRIC HELP Plse
Dave Haddon
Saskatoon SK. Canada
Not an electrician and trying to save a few bucks these days i am asking for a little advice. I was given present of a set of running board LEDGLOW LEDs. Did research..called LEDGLOW ( no help other than"he thinks it will be OK" )Some sources say do not wire them it will fry your system..others say it will be fine. Do any of the real knowledgeble RAM guys on here know what the safe method of putting these lights on would be. ..T Taps..relays..?? They are courtesy lights when you open the door and additional signal indicators. They are mounted at each weld seam at the running boards. Can amyone take the time to give me the method that is safe ..or should I take them and put them on the shelf...Thanks fellas.
RedRAM21
SoCal
5.7L HEMI
I am new to RAM, but wiring is wiring.
I read through the install instructions, they say to use a rely, exactly why I am not sure, LEDs do not usually draw a large amount of current BUT, since they say to use it then be safe and use a rely. The only problem I can see is where they tell you to connect pin 30 and pin 86 to a constant power source.
To me I would run pin 30 to a power source and add a minimum value in-line fuse, then wire Pin 86 to an activation source, i.e. a switched power wire and pin 85 to ground. Pin 87 goes to the load (LED Lights).
NOTE: The FUSE on pin 30... check what they call out for a fuse, drop the value of that fuse by half, check out if it works (doesn't blow out), if it does blow out raise the value of the fuse until you find one that lives, trying to keep the fuse value as small as possible and then switch to a fast-blow fuse of the same value. (Sometimes a fast-blow fuse doesn't work out, if it does you are that much safer).
The next thing to check, the manual calls out using the Interior Light wiring to activate the Courtesy Lights, OEM wiring can sometimes be minimum at best, it will carry the current needed but easily overloaded. Make sure the wiring you tap is capable of carrying the total current load of both the interior lights and the new lights.
Sounds like a PITA but once you have a fused power line that works, fused as close to the power source as possible, and the proper wire size, the fuse will will cut off the power source as fast as there is a current increase and the wiring shouldn't get hot.
This is only a suggestion but the way I would go about it, thinking about possible problems you have raised.
Sorry if I went little too far.
Also, take into account I don't know exactly which lights you have, so tread lightly until you know what the needs are.
Dave Haddon
Dave Haddon
No that is great and thanks for your comments...appreciated...I am thinking for rhe $40 USD I invested i will pass this on to whom ever might want it for the cost of the shipping..I think it is a problem I do not want for what I will gain
Cheers.
