Electric windows
DALE Tillman
O8 ram. Drivers side rear window and lock not working. Its not the motor! Sometimes it works mostly it don't!
Daw14
South Florida
Most likely the switch, I think rain gets in these ,and over 14 years old may have developed some corrosion.
tron67j
Maryland
Had a problem with my 03, but it was other windows that would not work. In earlier gen 3 trucks a small solder joint fails routinely, you can fix it but I just replaced my whole unit in driver door, worked perfectly after that. Good luck.
joshhhh
