Electrical problem
DodgeFH413
Johnstown, Pa.
My 07 1500 crew cab radio and odometer lights stay in when vehicle is off. Draining battery. Turns off occasionally when I insert, turn key and remove. Anyone run into this issue?
Recoil
Just asking, but you aren't turning your key to accessory and able to remove it? I had to replace the ignition tumbler on mine because I could turn the key all the way back to accessory and the key would come out.
