Trafficjams4u
Thanks ahead of time for the input. I'm at my wits end.
Problem happened while driving down the road. The truck shut off and I was just coasting. I tested the fuel system and it wasn't pumping so I replaced the fuel pump. Truck started right up. Went to drive it around the block and noticed that the turn signals wasn't working, so I took it home and this is all the things I found wrong.
The headlights come on automatically, but I dont have automatic lights. The fuel gauge, turn signals, brake lights, cargo lights and cruise control dont work. that is all I can think of that doesn't work right now without getting a bigger headache.
My mechanic has a dodge of the same year so he swapped the light switch and turn signal switch with his, didn't fix it. unplugged the main harness that goes to the rear end. didn't fix it. unplugged dash cluster, didn't fix it. Bought and installed new TIPM and ECM, didn't fix it. Now my mechanic is unplugging every harness he can find and uninstalling all after market items and testing that.
He has had my truck for 2 months, we are both going nuts. Thanks
