Electrical Troubleshooting Assistance Requested
FrustratedOldMan
5.2L
Strange problem with my 1998 Dodge Ram 1500 5.2L, Auto, 4x4, Quad Cad, Laramie Edition
Issue:
- Activating left turn signal turns on windshield wipers
- With fog lights on, turning on headlights turns on windshield wipers and illuminates left turn signal indicator with a dull light
- With fog lights off, headlights operate normally
What I have tried:
- Aftermarket tail light bar removed. This had been installed and operation normally for over a year.
- New radio installation removed.
- Turn signal, multi-function switch replaced.
Nothing tried has changed the symptoms at all. Any ideas or wiring PDFs that someone can share?
Thank you in advance for any assistance.
WilliamS
Tampa FL
There is something tied into the left turn signal/driving light circuit to the wiper. Makes me think for some reason the harness has and issue and those 2 wires are touching. Or in the fuse box. Do you have a heavy corrosion issue or any sign that animals are under the hood?
F
FrustratedOldMan
5.2L
Nothing noticeable in the way of corrosion or animal damage. I was going to start metering out wires starting at the wiper motor this weekend. Looking at the wiring diagrams for both the wiper and turn signal this after noon, I really don't see much common except for the multi function switch. I was gong o start there and work my way out.
That is of course unless someone on the forum comes up with a better approach :)
jlbayes
2001 & 1997
5.9l cummins
Start looking for shared grounds.
crazzywolfie
under the truck
i would be looking at grounds also. normally the signal indicator only come on with the headlights when you got a bulb out or something is using it as a ground.
stimpy433
IOWA
Check your fuse box for corrosion, I've read other threads where people have had strange things like this happen and corrosion was the cause.
SportRam00
Joppa, MD
Magnum 360
I would also look for wires that may have rubbed together. Start probing wires while activating the various switches to see where the current is coming from.
Sounds like a wiring issue... But could also be a ground problem as well.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
Pull out your multi-function switch and check the wires in the big connector. Over time, especially if the steering wheel is shifted up and down a lot, various wires can pop loose from the connector and cause goofy issues.
When I first got my truck, the low beams would randomly cut out and eventually got to the point to where they wouldn't work at all. I replaced the multi-function switch, did nothing. Pulled it off, looked at the connector and found that the hot for the low beams had popped out. Pressed it back in and haven't had a problem with the low beams ever since.
This connector houses a ton of hots for various stuff in the truck.
