Emergency Brake Cable Removal
03marauderman
I'm stumped...Removing the emergency brake cable from my 2000 Ram 1500 4X4 & found the spring at the end of the cable, inside the brake drum area is too big in diameter to pull through the backing plate ???? - Don't want to cut & destroy the end of the cable as I want to reuse it....anyone run across this before? Thanks
Merc225hp
NA
truck
gas
You have to take the spring off the cable end and then it will fit through the hole.
03marauderman
Merc225hp....Yup figured it out....after I took a break, had lunch, & went back to it... Thanks for the response....
