Engine miss????
Pa.hemi.ram
Pittsburgh
Hemi 5.7, 6" Rough Co lift, Fuel wheels, Bully Dog Gt, K&N CAI, Magnaflow Exhaust
Ok here's my problem. Bought a stock hemi ram and in the first week did a 6 " lift, 37" tires, magnaflow exhaust, k&n air filter and Bully got gt programmer. Now after doing that all the same week I have a terrible miss in the mid range when I lug the truck up a hill. If I get on it and kick it down it goes away. It's pretty bad miss......I turned off my MAF feature in my Bully dog so it always runs on 8 cyl. Don't want to start tearing stuff off. Checked intake for leaks? Put Bully dog on stock program. Any one have any miss issues with magnaflow exhausts??
stoviAZ
I doubt it is your exhaust, do you have any way to data log?
Sent from my LG-H910 using Tapatalk
crazykid1994
Check your spark plugs. Under load they can miss if they are going bad
huntergreen
Marine Corps Navy Badge
Agree with above. Go back to stock tune.
Pa.hemi.ram
Pa.hemi.ram
Pittsburgh
Think it might be my Bully dog? Runs worse the higher I go up in performance. Stock misses slightly here and there. Regular misses more and performance it misses a lot more. Still have that slight lugging in stock though? I have premium gas in it. Thought maybe that was problem? I have 40,000 on my truck. Maybe I will check the plugs? Not sure how to data log? I'll look into that tomorrow with Bully dog programs. Maybe it will tell me something?? Truck ran awesome before? Don't get it? It should run awesome with those upgrades I thought? Don't get it.....
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
Someone will correct me if I'm wrong, but I think the service recommendation for plugs in a 2013 Hemi is 30,000 miles and that changed to 100,000 starting in the 2014 RAM's. So if I'm right that may be the best place to start.
Pa.hemi.ram
Pa.hemi.ram
Pittsburgh
I'm going to try that this weekend. I hope that's it. What spark plugs you guys recommend without going ridiculous? Also how about oil/filter brand?? Full synthetic?
Pa.hemi.ram
Pa.hemi.ram
Pittsburgh
I'm going to try to do an "uninstall program" n my Bully dog too. Thinking that you guys might be on to something about the plugs because higher mode I put it in on my Bully dog the worse it gets. Soooo every level that gives it more spark makes the problem worse....
Pa.hemi.ram
Pa.hemi.ram
Pittsburgh
Put new plugs in and good as new!!! Thank you guys! Runs great now.
