Engine start issues
Dropdeadwasted
Charleston, sc
I have a 2010 dodge ram with the 4.7L and am having issues with starting. Most times I have to turn the key 5-20 times to get it to turn over. Each time I try, it gives me a short burst but doesn't turn all the way over. Similar to what you would encounter with a low battery. Eventually, it will turn over and then the truck runs fine. I've heard that the WIN modules are notoriously bad in these trucks. I'm wondering if anyone can has encountered this problem and if replacing the WIN did the trick.
Part 2: If replacing the WIN is the recommended fix, I'm wondering if replacing it with the remote start version of the module will give my truck the remote start feature. I've found a website that offers new modules with 2 keys already programmed to my vin for about 600 bucks. The remote start and non remote start modules are the same price on that website.
Tach_tech
5.7L HEMI
If you hold the key in the start position and wiggle it up and down and then it starts, it’s the WIN module.
If you buy the remote start kit, you’ll still have to install the remote antenna and possibly the hood switch, also will need to be programmed.
D
Dropdeadwasted
Charleston, sc
I'll try that when I get off work.
The remote start question that I was referring to is they have 2 WIN modules available. Both look identical but different part numbers. One says w/ remote start and the other says w/out remote start. I didnt think that it was that easy but thought I would ask just for the hell of it
feets
