Engine swap
Darren365
Alaska
5.2 stock
hey all,
ive got a 1984 dodge ram w150 and am considering dropping a "ATK HP47C Chrysler 440" in it. does anyone have experience with this and know if the mounts will fit and how well it would link up with the transmission?
thanks
u2slow
BC, Canada
Cummins 6BTA
The 440 bigblock doesn't bolt up to the same trans as a 318/360 or slant6. Also need the 3/4ton booster to clear the wider engine.
Mounts should be easy. I landed a Cummins in place of a 318. Frame seems to be the same in that regard.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
like U2slow said, you'd likely have to drop more $$$ to go big block. you could do the ATK 408 stroker which is a magnum small block. or if you do go whole hog, $10000 will also get you a 6.4 hemi crate.
rockyj69
