Team RAMrod
Absolutely love my Ram, just wondering if anyone else has found a way to have your truck lower when shifting into park without having to press the lowering switch?
It could be this one. Again I don’t have air suspension so can’t try to confirm. It does say if you open a door before it lowers or raises it stops until the issue is corrected. See post above for page 318 about doors.Absolutely love my Ram, just wondering if anyone else has found a way to have your truck lower when shifting into park without having to press the lowering switch?
I wish there was a setting to have my mirrors turn in when I put the truck into Park or turn it off. That would be great! First world problem of course, but hey why not?
It takes over 10 seconds to lower from aero down to entry/exit height on my truck with ORG. I am not patient to wait that long every time I shift in to park for the truck to lower. I would rather only have it lower when I ask it to, not automatically.
If you set the switch to normal height it will go to normal as default and then down to aero mode at a certain highway speed and then return to normal when at a slower speed, and return to normal after entry/exit mode.
If you manually with the switch set to aero mode it will stay in aero mode even at a slower speed or stopped, and return to aero mode after entry/exit mode.
I have the Off Rode Group with the normal height 1" higher than non ORG normal mode. At 1" higher = more wind resistance and worse mpg so I ride in Aero mode a lot. My Aero mode is still 1/2" higher than non ORG normal.
Never heard of a "lowering switch". But if your truck has the 4 corner air bags on it, then yes, the truck can be lowered. My buddies 2018 Rebel, has the 4 corner air bags on his truck, and he can lower/ raise the truck by about 6 inches right from the key fob. I've seen it.
