New owner of a 2014 Ram 1500 (and loving it so far)...
So I was reading the owner's manual (I know, right? Who does that?). The section about setting up the four corner items in the EVIC display says that I can set each of them to any of the following items:
But when I try to set this in my truck, Trans Temp and Oil Temp are missing from the available choices. I would like to have my EVIC display Trans Temp and Oil Temp in the bottom left and right corners of the display so I can keep an eye on them.
For now, I've set the custom gauges to display Trans and Oil temp instead, but that just shows a graphic display, and not the actual temperature in degrees, so it's less useful; and besides I'd like to use the custom gauges for something else, so this is not ideal.
I'm just wondering if there's a software update that I don't have. Can somebody look at theirs and tell me if you have Trans Temp and Oil Temp as available choices?
I'm a software geek, and there's an old saying in my field that any time there's a discrepancy between the software and the documentation, assume the software is correct and the documentation is wrong - that may be the case here - I just want to make sure I'm not missing an update that might enable this, because it would be really useful to me if so.
Thanks.
- None
- Compass
- Outside Temp
- Trans Temp
- Oil Temp
- Time
- Range To Empty
- Average MPG
- Current MPG
- Trip A
- Trip B
- Trailer Trip (Distance Only)
- Trailer Brake Gain
Thanks.
