Exhaust and headers
crazykid1994
Alright so I'm looking at who has headers and exhaust. What are you running. I'm debating on arh stainless works or kooks long tubes with high flow cats and a muffler swap. Debating on flowmaster 817477 or custom carven with 2.5" tail pipes. Opinions? Going to have s&B intake. Don't want something super obnoxious. Maybe custom dual carven tr 2.5" with x pipe no resonators 5" tips. Should I keep the y pipe to 3" instead of an x pipe and do a 3" in out muffler
doug2013
Georgia
2009 Dodge Ram 1500 Laramie
I have the competitor series bolt on muffler right now and I love it. Its a tad loud but only when you get on it. I am also getting kooks long tubes here shortly. Wasn't sure if I was going to go do a custom true dual setup with dual carven mufflers or an x pipe with the carven muffler i have now.
crazykid1994
crazykid1994
I'm going to follow you and see how it turns out. I'd like a nice healthy growl and good airflow. I know the 2 1/4 pipes aren't really restrictions but I figured 2 1/2 with an x pipe to dual mufflers would be better since that's what comes off the headers and dual mufflers sounds fun saying it
Alrynate
JBA LT Headers
Got a pair of JBA LTH for Bday. Do I need to get new catback? Only have a muffler swap at this point
crazykid1994
crazykid1994
You will need the jba y for the long tubes if you don't have it already.
theviking
I have ARH catted headers, fitment was perfect. Also have a MF cat-back but my truck is a 2500 so not exactly apples to apples. But I would focus on a less aggressive cat-back muffler setup since you will have headers as well. Otherwise it will get loud quickly.
crazykid1994
crazykid1994
That's why I was debating on the FM 817477 catback kit. Which motor do you have? Any videos of it
theviking
I have the 6.4, and an MF 19200 kit which uses their biggest 3.5" muffler and a resonator. It's manageable with minimal drone but under load at part throttle you can still hear it. Nice thing about the 1500 trucks is you have a lot more options.
[yt]k8uWuJobUZU[/yt]
crazykid1994
crazykid1994
That has a nice rumble too it. How much did the sound change when you added the headers? My other vehicle only has a muffler swap so I'm not sure how much louder it gets
theviking
No, because I did it backwards. I first added the headers, hoping that would give me a more aggressive sounds than stock. But the massive factory muffler with it's internal flapper setup was so effective it sounded almost no different at all after the header install. So then I added the cat-back.
Again, you have a lot of additional exhaust options that I could only dream about. I would suggest focusing on whatever is least likely to drone and has a sound style that you're looking for. As a point of reference to your question, I also have a 2012 Mustang GT. At first I just swapped mufflers, then later added Kooks catted long tube headers. The exhaust got much louder after the header install, so IMO it does make a big difference.
crazykid1994
crazykid1994
Thank you. I might try headers first hadn't even thought about that. The trucks have a nice tone to them although very quiet and headers add a little to the performance aspect as well.
theviking
The headers, along with a tune, will make a very noticeable difference in performance. I've gotten my truck down to about a 6.5 sec 0-60 with my mods and most of that came from the headers and tuning. On a 7200lb truck.
G3SRT
running ARH longtube 1 3/4", ARH ypipe with cats, carven progressive muffler, and S&B CAI, paired with tune.
mean loud cold start, deep/semi-loud during normal operation, and full V8 scream under full throttle.
definitely a power gain mod combo; just hate the drone the muffler causes between 1500-1900 rpm
crazykid1994
crazykid1994
If possible could you post a video. And my average rpm range is 1500-1800 around town...
theviking
That's pretty sweet. 6.5 seconds? That's gotta be a nice jolt back in the seat
https://youtu.be/X7VYJJ6tBjU
Long tubes and Dual carven with xpipe
https://youtu.be/d8uAYA5RO-A
Arh long tubes and fm 50 cat delete and res delete.
I'd like to keep cats at least
No, the jolt comes from the Edge torque converter. It's a great mod and I would suggest that immediately after the headers and tune. Makes the truck so much more fun to drive around town.
Edit: Forgot I said that, you have the 8 speed so no converter for you:)
crazykid1994
crazykid1994
Yea I was going to make that comment. I still get a good launch. I've also got the 3.92 gears instead of 3.21 so I get a jump off the line already.
