exhaust downturn
ram15
Mendocino, Ca
So I've been thinking of getting rid of the stock piece of the exhaust that goes up and over the rear axle and replace it with a downturn right behind the muffler. Do you think there will be any ill affects if I did this. If someone has done this let me know how of went.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
alot dump ther exhaust. wont do anything to your truck. make it louder and a little more drone in the cab.
Hotroder383
Washington Mo
318 or 5.2 which ever you want
Yep, and in MO you wouldn't be able to put a camper on it. Exhaust must exist 12" past last opening window or out the side in case of truck with camper. Now if you never plan on having a camper this isn't a big deal. I have run turn downs on a few cars I ran, makes for a cleaner look outside the car but under it all the black soot makes it a lot dirtier to work on.
Grab a 90 deg turn and some extra pipe from your local parts store and run it out the side, avoid all problems and have a louder truck! =)
