Exhaust manifold gaskets
BEAST19
Hello, I’ve got a 2015ram 5.7L with some arh long tube headers snd I’ve got to replace the exhaust manifold gasket. I hear good things about remflex . I used a mopar gasket now with locking header bolts but never got em retorqued and have a small leak. I want to replace . Can someone who has done it verify the specific remflex gasket I’d need ?
BEAST19
BEAST19
I installed shorty headers on my ram and used remflex gaskets they're excellent gaskets
Did u use locking header bolts ? Did you retorque? If so when?
Are we having fun with the locking tabs on your stage 8 bolts,lol. Throw the locking tabs and clips away once you manage to remove them,they'll cause you more issues then you want.Besides whens the last time you seen a header bolt fall out? The tabs keep you from easily retorquing the headers,so you're prone to more gasket leaks.BTW don't bend the Remflex gaskets,they don't take well to bending,and don't go nuts on tightening them down,they only require 20 lb-ft of torque.
BEAST19
BEAST19
Makes sense I suppose. I’ll toss the tabs. What’s the retorque process ? Is there a way to do it while it’s up on the lift? For example , get the engine up to temp for a period of time then let it cool then retorque? Looking for advice on that too. Thank u
Remflex says no re-torquing required,but i usually snug them up after a couple heat cycles,then check them once in awhile afterwards. I'd run it up to temp once,then check them if you have it on a lift.Start from the center and work your way outwards in an ever expanding circle when you're tightening them down if you don't have a torque pattern for them.
BEAST19
BEAST19
Awesome thanks for the advice [emoji1306][emoji631]
Simpleman
New jersey
No I used the bolts that came with the Kooks headers and I did 1 heat cycle and rechecked them and all is good
EdGs
FL
This conversation is 6 years old and last time Simpleman was heard from was May '22 and last comment was 4 years ago.
Exactly why, after a certain time without posts, a thread should automatically lock. If the OP wants to add to it for some reason, a moderator could unlock it, and the thread would become active again until another period of inactivity.
