exhaust options w/ roll pan
the codes
Houston, Tx
Magnum 5.2
so I was thinking and am curious, what's everyone running who has a cutout? anyone have tips? anyone cut the roll pan and put the tips through it?
looking forward to the responses
Tapatalk Addict
omega88
If it were me, I'd either go out the side, in front of the rear tire, or dump the exhaust just after the axel.
the codes
the codes
Houston, Tx
Magnum 5.2
hmm never really been a fan of the side exit exhaust, what to do what to do
Tapatalk Addict
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I like the clean look of a dumped exhaust without any tips showing. The only way to run your exhaust ith a rollpan is dumped, or if you cut into the rollpan. I have never been a fan of exhaust tips showing below the pan.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Dumpage can be pretty droning depending on where the dumping is done. It may the most budget concious idea, because modding a pan to look good with tips isn't cheap or easy for the novice.
I don't mind side exhausts ie: Nascar style. Probably works better on a lowered truck than a lifted one because the pipes aren't in your face.
the codes
the codes
Houston, Tx
Magnum 5.2
hmm I suppose tips would ruin that clean look.
anyone have any pics of side exhaust they like?
if I don't find something that really catches my eye may just dump it.
Tapatalk Addict
Hollabakzach23
Lafayette, IN
Thinking about doing dual pipes with them exiting right behind the rear tires. And I have a roll pan. I think it would look pretty good
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
The best way to run a dumped style exhaust with a roll pan is to run it all the way to the back, over the axle, and then have the tips angled down where they are even or just above the bottom edge of the pan on either side. Hard to explain but you don't see tips and there is no drone.
reddot
Wolf Point, MT
5.9 cummins
totally agree. If you have a roll pan do not show the exhaust out the back at all. If you want to have a cut out do the muffled exhaust out tips on the side and dump the cutout.
the codes
the codes
Houston, Tx
Magnum 5.2
this thread is worthless without pics! but I like what I am hearing guys
Tapatalk Addict
ramthis9501
Oklahoma
5.2 V8
Dump it after the axle, it'll give you that clean look. Mines like that and I like it alot
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Nascar style lol
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Just the one, the gas tank is in the way on the other side
topherztoyz
