Nickrembecki
I have the dreaded exhaust tick. I have the stock exhaust. If I buy a set of headers, would I need a different exhaust or does it bolt up to the factory exhaust? I have a 2014 ram 1500 with the 5.7 hemi
You mean taking the factory manifold off with the head on the truck is a PITA?From what I've seen, there are direct replacement headers that bolt up to your factory collector pipe (where the exhaust pipe bolts to your manifolds). I have a set of shorties on my 09 that bolts directly up to my factory pipes. Granted, mine are a really huge PITA if you are trying to take them off with the heads on the truck. The factory ones are easy to get off just expect a broken bolt or 2. Easiest way i've found is to weld a nut and a washer to the broken stud and it should come right out. They are aluminum heads so you won't have any issue about accidently leaving a couple tacks on the heads themselves. These below are what are on my hemi now. Like I mentioned hard to unbolt with the head on the truck so when I did my cam job I left them bolted on and it gave me an extra go handle when pulling the heads so I'll take it.
https://www.americantrucks.com/dodge-bbk-1-34in-tuned-length-shorty-ceramic-headers-0917-57l.html
In NY where I’m from, now it’s illegal to modify the exhaust and can not have cut outs. I was looking at flowtech shorty headers from JEGS and I wasn’t sure if most shorties would bolt right up or if I would have to change the whole exhaust for it to bolt upOf course you mean behind the headers, it will or it wont, no big deal anyway. Shorty or long tubes, if you get long tubes you will need some work, some shorty's might bolt up. If you want something badass, look at exhaust cut outs, they are cheap and with a press of the valve you bypass muffler, hehe.
search shorties with oem fit and make sure legal in your area, I say that because in CA only a few are CA legal.
Sorry, the after market headers were a pain. I didn’t replace them, the previous owner did. I’ve seen and been told the stock header is fairly easy to take off since it’s essentially in a straight line unlike the bbk headers which I have that have ridiculous bends I assume to make them equal length. The stock headers shouldn’t be too bad just worst part would be any broken studs but mentioned before pretty easy to weld a nut on top of the stud and unscrew it out. I’m no good at welding what so ever but now that I’m remembering it was for a valve cover bolt I had broken on the rear of the head. No room for a drill or anything to pull it out with.You mean taking the factory manifold off with the head on the truck is a PITA?
