Exhaust
Dansraminit
Connecticut
Hey everyone, got a 2015 1500, looking for a muffler delete kit, or have a shop do it. Thoughts and places in the Watertown CT area.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Just removing muffler?
D
Dansraminit
Connecticut
Thanks, I saw the kit, I don’t mind doing some work myself, but I didn’t want to drop $200 and not like the sound. You can only listen to so many YouTube videos.
Mike htx
Houston
Hey I’m new to this forum thing, I have a 2016 ram 1500 hemi. I am looking for exhaust that sounds good but isn’t gonna be too loud or drone. Had flowmasters on my 08 and towing was a droning nightmare. I want a little rumble but not much cab noise. Please let me know if you have any suggestions, thank you
Burstingbb
Charleston
My Carven Competitior without resonators has zero drone. It had a little bit of drone with resonators on and when I took them off it went away. But that may be on the loud side for you, I came from straight pipes so too me it is quiet.
Here is a clip at cold start in 90 degree heat
https://www.instagram.com/p/BxzwsRnhYuz/?utm_source=ig_web_copy_link
William Hastings
Aston, PA
Look up the borla pro xs thread, you can make a clamp in version yourself with buying an extension pipe or get the weld in version. Having it for awhile, it does drone slighty at certain rpms, but in 8th gear on the highway its quiet, highway driving is why i had to get rid of the carven progressive, droned bad at 1500 rpms, i have the 3.21 gears, so i think that matters, most who have the 3.92s dont seem to mind carven mufflers
Hydraplane
Navarre, FL
I had a '14 1500 5.7 8 speed. Local shop made a bolt in muffler replacement pipe. If you can get a pre fab kit it would work well. You will like the sound until MDS kicks in at low speed. I usually selected manual mode in town to avoid the MDS growl. Did not detect any change in power or gas milage but did not put it on a dyno either..
Burstingbb
Charleston
I have the 3.21 gears as well. Did you leave your resonators on? Mine droned around 70 - 80 and then when I took the resonators off it removed the drone
William Hastings
Aston, PA
I didn't take resonators off, bought the borla, sold the carven for close to what i paid for it. Wanted to keep a simple clamp on setup
abouttobeglue
Gibson mwa, sounds good, minimal drone, pypes violator also has minimal drone as well. I've had magnaflow and flownasters before, all had drone at the 1700-2100 range.
gdawg55
GA
I've had lots of mufflers on my truck. The three that had good sound and minimal to no drone are Solo Performance Mach 44, Borla Pro XS, and Flowmaster 50HD. Every muffler I've had shorter than 18" has droned. I have found out after some experimentation, that the Moe's 5" tips I was using were increasing the drone. I have switched back to stock tips and the slight drone I was getting with my 50HD is completely gone. Makes me wonder if this would have helped with some of the other mufflers I had that droned with the larger tips.
William Hastings
Aston, PA
Finally paired the borla with 5" carven tips, only drove around the corner but it sounds awesome. I hope ur wrong about this one gdawg! Hahaha. Ill do some highway driving friday on the way to work and report back
gdawg55
GA
5" tips didn't affect the Borla. Sounded great with them. You will like.
Nick@GotExhaust
Supporting Vendor
SC
FYI guys we are running a sale on Borla products starting right NOW. Contact us for pricing on what ever you are looking for!
McBroom
Denison Tx
Hemi 6.4L
McBroom
Denison Tx
Hemi 6.4L
I’ve got 2 videos on YouTube of the warm and cold start up. It’s definitely worth checking out.
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
McBroom
Denison Tx
Hemi 6.4L
Solo Exhaust Delete Kit is what ya want
I love my truck!
joshhhh
