Experience with Spyder 5030078 headlights...
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Just curious if any of y'all have or have tried, or know of anyone who has or have tried the Spyder Auto CCFL Projector headlights for a 2008 Ram... Thinking of buying a set but I am seeking some reviews, thanks.
Robocop_9
West Virginia
I'm running these spyder lights and have no issues I did put a bead of silicone on them before install as an added precaution
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
SAVE YOURSELF THE TROUBLE AND DONT BUY THOSE, those and recon are the same light and ate 100% complete garbage!!!!!!
ive had a few sets of those and they are all horrible at best for visibility at night
corneileous
corneileous
Podunkyville, OK
All of those eBay headlights that I've ever had and seen have been junk. They leak and the beam patterns are terrible.
Hmm. Well, if it's any consolation, I wouldn't be buying these from someone on eBay.
corneileous
corneileous
Podunkyville, OK
Where did you get yours at? How long have you had them and what do you mean by putting silicone on them before installation? Thanks.
corneileous
corneileous
Podunkyville, OK
Okay, if not these, which would you suggest? These would cost me about 300 for the pair do I have as hoping they wouldn't be cheap.
Demon-HeMi
Houston
$300 would be you getting ***** for them!
let me find a pic to the ones i suggest that will be the best ones for you to run if you are wanting aftermarket projectors
Demon-HeMi
Houston
These are the best plug and play projectors you can get, they adjust easy and work pretty well, and when i say they adjust easy i mean just like OEM, no removing the light, turning a screw hoping its the right amount
They come in chrome and black, also have the option for LED or CCFL halos, CCFL obviously being brighter.
The CCFL ones cost around $200 and the LED ones cost around $150
Here is the brightness comparison
I personally like the way they look at night, in my opinion with the fit and function of them are could be mistake for an OEM upgraded headlight
If you are curious about any other 3rd gen lights let me know, ive owned em all... lol
Demon-HeMi
Houston
The ones you asked about look good on the bench but the output is no better than your parking lights...
corneileous
corneileous
Podunkyville, OK
What's the brand of these?
Robocop_9
West Virginia
Mine were from amazon I believe. A lot of aftermarket lights can leak so you silicone them around the joint to be safe.
corneileous
corneileous
Podunkyville, OK
Well, there's these like what Demon-HeMi posted about in his post #9 and then there's these that are significantly more expensive... Thoughts? Both are made by Anzo.
Demon-HeMi
Houston
the more expensive ones are so pretty much because of the bi-halogen projector, i havent owned a set yet, but from people i know with them they are about as good as the other, that will come down to your budget and your taste on look, personally i dont think the looks makes up for the cost difference but either one will be a good light
corneileous
corneileous
Podunkyville, OK
So, the 111315's just use a dual, high/low bulb? Says they use an H7.
The others, the 111103's say they use a H1 high beam and a H3 low beam.
I'm more interested in light output than looks. Does the set you have, burn both bulbs at once when your high beams are on or do the low beams go out when you hit your brights?
corneileous
corneileous
Podunkyville, OK
Well, I called Anzo, got a few questions answered but now I can't figure out which style I like...lol. Help me out.....[emoji41]
Or these...
