Factory Trailer plug removal
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
can you remove this from under the bumper? like unscrew it from the face plate so to speak? I added so LED lights that come in while in reverse a few years ago and I replaced them a few months due to 1 burning out. I noticed that they are now dim. I went under the truck and touched the main connection and they both got bright again. I thought it would be easier to trouble shoot if it was off and I swear I think I took it off when I installed them the first time but not quite sure.
Ken Hansen
Murray, UT
I'm looking for an answer for this as well.
Did you ever figure out if the plug could be removed without removing the whole bumper?
bdc2
Ks.
Drop your spare tire and the back side of that plug is easy to get to and figure out the removal.
The wiring plugs into the back of 4/7 pin plugin the bumper. You may or may not have to drop the spare to unplug the wiring harness.
For tailgate light bars, the CURT 56584 5-Pin Trailer Wiring Harness ( https://www.amazon.com/dp/B007EA6WQU/ ) can be used keep the wiring Plug-N-Play
1500ram12
5.9L Cummins
Sent from my motorola one action using Tapatalk
It's a little tight but you can unplug the connector without lowering the spare.
2018 Ram 2500 6.4L Hemi Tradesman
