Fender Well Push Pins
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Hey anyone know where we can get these?
2013 Ram 1500 Crew Cab Sport (Not that this all should matter I imagine)
They are the black push pins that simple help hold the fender well guard in place.
RamThunder
Is it in the front wheel wells? Does it connect to the back of the headlights?
Sent from my Pixel using Tapatalk
RusslRam
Try Home Depot or Lowe's in the specialty hardware section. In the drawers
insanitize
Try an auto body supply shop. I was able to get the plastic anchors for my Jeep JK at one cheap.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Funny you should mention those--If you change out your factory intake to an S&B CAI you have to remove and replace those pins (actually remove the liner to take out the OEM pedestal)--S&B actually includes a couple of those push-pins in the kit.
I would think the stealership can special order them, as could any body shop if you have to have factory replacements. You might even see if S&B will sell you the kit they include in their CAI a la carte.
Perhaps the special connector bins at a home Improvement Center, as stated above, if you don't care what they actually look like.
JasonK94Z
Anderson, SC
I'm pretty sure places like autozone sell them.
MADDOG
Living in a Firepit
2013 black Crew Cab Express
I remember being in Lowes and they had a whole section just for Mopar parts mixed in with the nuts and bolts department.
Broyd
Rossland BC Canada
Have a look on eBay. Search for 'automotive push pins' or 'automotive christmas tree fasteners'.
If you buy them in these kits, you save a wack of money.
Craw
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Thanks for the responses. I will try to find more.
Craw
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Oh I have tried all my local hardware/auto stores. Here in what I talking about. For anyone that doesn't know what a fender well is. Need 5 in front on each side and 3 in the back.
R.L.K.
Bristol , Tn.
Yep , any auto maint place has them . Autozone , Advance Auto, NAPA ect ect ....
Sent from my SM-G900V using Tapatalk
Splash1962
Princeton,Texas
Rlaf75
East Hartford CT
2021 Bighorn
If you're talking about these, any auto parts store should have them. You just need the correct size because there are several different sizes available Screenshot_20220716-151458_DuckDuckGo.jpg
Most NAPA stores have 1 or 2 of those rotating Bins of those clips
The packaging will say Ford, GMC, Dodge or Chrysler, etc.
A little tip on how to remove them
If you are standing in front of your grille & have the hood open.
Say you want to remove that cover that hides the Radiator, ( i believe Dodge calls it a Sight Shield, it hides the Radiator, Condenser, transmission Cooler, AGS from Sight )
Purchase a set of plastic Trim Tools at any hardware or auto parts store
If POssible, don't just grab the plastic screw itself
Grab the Sight Shield that is under the plastic screw & lift them both at once
view this video as he removes the Sight Shield or s he calls it the Close Out Panel
He removes close to the front of the video
ClassicJoe
NC
Mine has screws (if we are talking about the same thing), but mine is a 2019 Classic (2018). I assume it is different from 2013 to 2018...
Wadejesu
Alabama USA
Fender wells have both, Push pins to old liner in place till you install screws.
