Dan Topp
- Aug 14, 2019
- 847
- 1,428
- Location
- Jefferson Wisconsin
- 2019
- 5.7
Honestly, I use whatever big name conventional is convenient/on sale.
I'm at 263,000km without issue. I think people are putting way too much thought into this oil thing, but do whatever helps you sleep at night.
Use Mobil 1 Extended Performance 5W-20 ONLY. Even on my used vehicles. Bought a used Dakota two years back from a fella I know who used only Redline. Had to rebuild the motor at 78K, yolu should have seen the bearings, or not !! Wonder how they managed to score like they did?
It does make you wonder since Redline is a better oil.
Maybe to long between OCI or cheap filters that stopped working?
The oil companies and synthetic makers can toot their horns about who's better than the other all day long. The reality is that just change your oil in the recommended manner and you'll never have an oil related problem. No matter what oil or brand you use. Period. All this "well I've never had a problem with 'Brand-X' oil" doesn't mean diddly. There's a bazzillion miles on the road from most all cars with zero problems with all types of oils. Sure, oil problems occur... when you don't take proper care of your vehicle. But do the right thing, and you'll never have issues (only few cases I've heard are from poor engine design *cough* Toyota *cough*)
I agree 100%.I say just use a major brand. Personally I don't use synthetic due to the price. I have never had a repair based on the type of oil I used. In fact I have owned over 30 vehicles and never had any repair based on oil supply or brand. I also say unless you are a petroleum engineer and have lab testing qualifications you should not be putting one oil over another oil. That's my 2 cent opinion.
I wonder why Mobil 1 doesn't meet the required Chrysler MS 6395 spec
Rotella 10-30 semi synthetic if your VVT is okay with it.Keep in mind that the Mobil1 oil typically has very little to no ZDDP. (Zinc Phosphate). I have a customer that bought a new 2006 Wrangler with the venerable 4.0L inline 6 that has graced so many vehicles of yesteryear. From the very first oil change, he did his own using Mobil1. At 60 thousand miles, the engine had a flat camshaft lobe. This was due to very low zinc present in the oil. Although the newer vehicles sport roller lifters, there is still high scuff friction on the piston skirts. You might consider researching this and maybe adding zinc with your oil changes. The caveate is that zinc shortens the life of the catalytic converters by a small margin. I've added zinc to my 4.7L Toyota since it was 100,000 miles. At 220K miles the converters had to be replaced. I'll take the trade off. Converters are way cheaper than an engine!
What brand of filter was he using. Was it starving the engine?Use Mobil 1 Extended Performance 5W-20 ONLY. Even on my used vehicles. Bought a used Dakota two years back from a fella I know who used only Redline. Had to rebuild the motor at 78K, yolu should have seen the bearings, or not !! Wonder how they managed to score like they did?
Doesn't matter how many of these oil threads I read I walk away unsure of which way to go. 3K miles and gotta make my mind up soon but want to thank all who provide their insight.
