finding a spacer
ready to get loud
my friend has a 99 dodge ram 1500 with a 4'' spacer in the front and 2'' blocks in the back. every where i look i cant find the 4'' front spacer. anybody know where i could find one
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Don't do a spacer.
Once you go above 2.5 in of lift in the front you need an adjustable track bar. Besides that, anything more than a 3in spacer is just plain damn dangerous.
R
ready to get loud
ok so ill do a 2.5 leveling kit. but what should i do to get the rest of the 2''
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Stacking blocks is usually a bad idea, however if you don't do a lot of off road flexing, you should be able to use a 2 in block for the rear UNDERNEATH the stock 3 incher.
I say underneath so that the factory bump stop distance is preserved.
Otherwise you can use a 2in add-a-leaf.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Use a 2in spacer. lol
I didn't say you couldn't use a spacer up front, I said you couldn't (well, definitely not recommended) use a 4 in spacer up front. Just remember that anything taller than 2.5 inches is going to REQUIRE an adjustable track bar ($$$) and longer travel shocks (that is if you want it to ride decent).
Stangshcky12
Oshkosh, WI
5.9 Cummins
To lift the front end more then 2-2.5" you'll need an adjustable trackbar/trackbar drop bracket, extended control arms, longer sway bar links/sway bar drop and longer shocks
Cheapest and easiest way is to buy a rough country lift or tough country lift that has all the parts you need
Check out this thread: http://www.ramforum.com/f58/lift_basics_2nd_gen_4x4_rams-25153/
Stangshcky12
Oshkosh, WI
5.9 Cummins
If you really want to piece it together (I actually have) Top Gun Customz sells lift spacers of all sizes but for the price you might as well buy a lift spring
R
ready to get loud
i looked at thier spacers and i was thinking could i buy the 3'' tuff country lift and just add the 4'' spacer they sell instead of the 3''
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Man you're trying to do things the hard way.
If you want a 4in lift, BUY A 4in LIFT. Trying to upgrade a 3 incher is going to put mucho stress on factory components you have left. Which, depending on the brand, will be quite a few of them.
Stangshcky12
Oshkosh, WI
5.9 Cummins
By the time you buy 4" spacers and shocks for that kit you might as well spend the money and buy a 5" RC lift and save yourself some money down the road
Their are some RC vendors here on the site that might be able to get a better deal
Dodge Suspension Lift Kit
Okiespaniel
Work, Shop, Computer
magnum, 5.9
It's my belief that 4 inch spacers fall under the law of diminishing returns. You really should consider doing 5 inch or 4 inch progressive rate springs. 3 inch spacers are silly enough <this from someone who runs them.
joshhhh
