First mods
Gump
Butte, MT
Have my '14 crew cab big horn 1500, and I want some opinions on best first modification(s). It's my DD, pulls a 8500# trailer, and may occasionally take a trip down the track. I'm torn between a Diablo I2 with hemifever tuning, or Bilstein 5100s to level it out. Was going to do a Vararam intake, but I've heard mixed things about their quality. Also I don't know if it'd be worth the money for something that drives 80mph and less most the time. Any other cold air intake seems like a waste of money based on past experience with other vehicles. Any other suggestions or insight on what really improves these trucks?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
The tuner will help with pulling all the way around, the intake will compliment the tuner.
The Bilsteins will make the truck look good, but may hurt mileage.
gofishn
Iowa
hemi 5.7L, 345 cu in
DeeZee Tailgate Assist
Dee Zee Bed Mat - Knee Saver when crawling in the bed.
Stock OEM Air Box Mod - all the bene's of a CAI without the cost.
Read about it here:
http://www.ramforum.com/1260399-post14.html
TufTruck 1211 springs - You tow, regularly. I love mine. Use your Google-Fu, these things should be OEM.
3rd brake light gasket fix - Every Single one of them will leak.
Fix it now, before your truck gets water inside of it.
Read about the fix , here:
http://www.ramforum.com/1360297-post19.html
Want even more ideas?
Read this thread:
Best Mods under $100
http://www.ramforum.com/f38/best_mods_under_$100-85823/
Good Lusk to you.
Gump
Gump
Butte, MT
Thanks everyone who have replied so far.
Gofishn, I really like that intake. I'm a fan of home built goodies, so I'll try that. I also fixed the 3rd brake issue. They washed my truck before I took it home and it blew the light. Was baffled why the "brake light out" message kept coming on.
gofishn
Iowa
Well, if you lke the air intake idea, and want it to be RAM AIr
https://www.pegasusautoracing.com/images/M/3623-PLUS.JPG
add this vent intake to the left side of your radiator. run hose directly to it.
I have not done this, jsut yet, but it is on my list of to-do's since I saw someone else do it to his 2014 ram.
Get it for $19 from her;https://www.pegasusautoracing.com/p...ce=connexity&utm_medium=cse&utm_campaign=3623
if link does not work google this
Air Inlet, Extra-Small Rectangle, 6 x 3.5 inch
roadshow
I'd do the Bils before anything. Not only does it make the truck look better but the ride is better and it reduces body roll noticeably.
DILLIGAF
Canadian Forces
Canada
Tuner with HEMIFEVER tune and disable that useless MDS :)
Gump
Gump
Butte, MT
I already caved and ordered the tuner. I'll get the Bils in a few weeks.
