first oil change
reefguy89
laurel de
i going to do my first oil change in my new truck tomorrow but not sure wat to use. I want to go synthetic, is there any thing i have to do special to switch to synthetic. So wat brand a type of oil should i get and would a fram oil filter be fine or is there a better one?
BigMike005
Miami, FL
You can never go wrong with Royal Purple.... been using it since the day i rolled out the lot
adamwilkes14
used to you would have to do an complete flush of the engine when changing to a synthetic from a conventional. However, now days, they are completely mixable and you can switch as often as you wish between the two at any time. You will find that allot of people (not here but in general) do not suggest Fram for a filter...NAPA Gold filters are great and are made by Wix...I have heard horror stories of the bypass valves sticking in the Fram filters, but have never experienced it myself.
Just remember to follow your manufacturers suggested oil change intervals even with the synthetics if you are still under a factory warranty.
txbass06
NE Texas
5.9 Magnum
^^Agreed. I use a Wix filter with Royal Purple
adamwilkes14
We used to blend/package Mobile1 here at our oil plant...they are some picky ********...
shadow11
Banned
Houston TX
Mobile one full synthetic is what I use with a mopar filter. The oil is the cheapest at wallyworld.
AWE Daniel
Banned
I bought a box of the purp once and used it for 2 cycles, then switched to mobil 1, I couldnt see any difference at all. I liked the feeling of knowing that I put the best oil in my truck, but at 120$ a box thats a 70$ oil change! With the mobil 1 its more of a 40$ oil change much easier on the wallet, and I think it does just as good a job in our trucks.
BigMike005
Miami, FL
Aaahhhhh but if you want the best, u must pay for the best.....
jus messing wit you daniel
reefguy89
reefguy89
laurel de
ok wat is a wix filter and where can i find it? Also since i dont feel like looking it up how many quarts will i need?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Ditto:
That is what I use.
I have had Fram failures and won't use them on anything I own. Failures have included the filter not threaded to spliting. When shopping if nothing else line up a few different brand filters and look at how they are manufactured. There is quite a bit of difference quality between them. Good luck...
txbass06
NE Texas
5.9 Magnum
You got a Napa nearby? The Napa Gold filter is the same thing
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Well in my truck I was using royal purple but since switched to mobile1 and a six filter. On the stang though I use quaker state or penzoil with the dreaded fram filter. I have had no issues.
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
Mobil one filter and full synthetic. I have a mopar filter, that I'll use in 1500 miles.(next oil change) That and a tranny flush are the next maintenance items. Then I should be good till, omg, 65k oil n filter. My truck is getting old!!!
txbass06
NE Texas
5.9 Magnum
I should buy stock in RP with all their product I've got at my house. A case of their ATF with a Wix transmission filter, 7 qts of diff fluid, and a case of 10W30 with a Wix and Mopar filter
