Fix for faded oxidized Bumper covers
griffo
Well i do computer and printer service and i was out side looking at my oxidized bumper and thought i give the rubber rejuvinator i have that i clean rollers on printers a try at rejuvinating the bumper cover here is a pic of it about half way done. It looks like it works real good.
It removes the oxidation not just mask it and it makes it feel like rubber again!
front all done
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Welcome to RF!
Nice work! Can you show us what you used...and where can you buy it? Office Depot?
G
griffo
Welcome to RF!
here is a link where i purchased it Rubber Roller Rejuvenator Can - fixyourownprinter.com i would not reccomend using a spray rejuvinator that you find on ebay or google searches as i do not know what it will do to paint etc...
Its real easy to apply no scrubbing or buffing just wipe it on let it sit for a minitue and wipe it off
loki223
Spokane, WA
Cummins 6.7
looks good, i wonder how long it'll last, or if it'll stay like that for a couple years.....
G
griffo
I have been using this stuff on printer rollers for years it doesn't just cover the oxidation like wax or armorall it resurfaces the rubber kinda like taking off the top layer so it should last as long as the orignal. At ten bucks a can you can rejuv the bumper 100 times alittle goes a long way
loki223
Spokane, WA
Cummins 6.7
if one thing can do the whole bumper, i would try it fro $10. but than again i don't have the problem of oxidating plastic...something to do with my steel bumper. definitely something i'll keep in mind though.
G
griffo
you can do a bumper many times with 1 can
WhiteExpress
Midland, TX
I was just going to order new plastics for my Dad's bumper. I might still, they are sun faded and have turned green. *WTF?*
Tempting for $10 to just try this.
G
griffo
someone told me my next project should be to fix the head lamps so i figured wtf ill try it. in less than the time it took me to have a smoke this is what it looks like
magnum318
Nebraska
Magnum 318
Those are some really nice results.
You should buy the stuff in bulk, repackage/rebrand it and sell it to the automotive market. :)
Sent from my BlackBerry 9350 using Tapatalk
G
griffo
How does this work on tires?
I have not tried it on tires yet but I use it on rubber rollers in printers and it cleans them good. I would only use it on the side walls if I did use it on tires
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Okiespaniel
magnum, 5.9
Correct, as you would any rubber dressing or armor all type product.
G
griffo
This stuff is more of a deoxidizor than a tire shine or cleaner
Okiespaniel
magnum, 5.9
So it removes the oxidisation(sp)from rubber and leaves it in a natural state?
I ask this because the bumper material is more of a plastic than a rubber. So this product should, on rubber tires remove the oxidsation and leave the tire black.
Westley's bleachwite does this as well, but it is very hard on the rubber because it is a bleaching /degreaasing compound. I would llike to find somethng not as harsh. I dilute Bleachwite 1:1 but it still is pretty harsh.
What is the long term effect of this on rollers...does it dry them out and cause to decay after so many cleanings?
Pardon my skeptisism...but sometimes too good to be true is just that.
Since you have the product on hand, could you try ot on a half a tire, or a small area?
G
griffo
It takes a worn smooth roller and removes all the paper dust and adds gription (if thats a word) and makes the roller feel like it did when it was new.
In all the times i have used rubber rejuvinator i have never seen it mess a roller up if anything i have used it to make a roller last long enough to order a new one and in those casses the rollers were worn down so much that the pressure between the roller and paper was minimal.
Like i said this was the first time i have tried it on the bumper and head lights only time will tell how good it works. so far it is holding up in the rain and the hot florida sun. when you first apply it thr plastic/rubber(the bumper covers are kinda inbetween rubber and plastic not to soft and not to rigid)it feels kinda sticky after you wipe it off in a day or so that stickyness goes away or you can wash with soap and water. on the head lights i wipe it on and wiped it off then washed with soap and water as they are more like plastic then rubber. I HVAVE NOT TRIED THIS ON MY ACCURA HEADLIGHTS BECAUSE I DONT KNOW IF IT WILL DAMAGE THEM. i will try it on some i find in the junk yard first
I will try it on an old tire i just took off the truck and post pictures
G
griffo
i finished the bumper cover and the other headlight
sorry didn't gat a video to hard to hold and do at the same time
moates49
