FUS88
Hi there,
First thread for me
So I have mentioned this in the AlfaOBD thread sometime ago, and did not find any solution.
I have a 2014 ram 1500 laramie with the projector healight, and the problem is, when I pull the multifunction lever toward me for -flash to pass- it only flashes with the high beam, low beam does not turn on.
This happens even with the low beam on at night, when flashing to pass, only high beam flashes, but the projector shield does not flip down to allow the projector high beam. I have to push the lever to get both the high beam and projector shield to operate together.
So, is there something wrong in my case? Or is it like that in some Rams? Also, is there a way I could get all lights to flash when I pull the lever?
In case it matters, I live in Saudi Arabia. So, the truck could have some different configurations than the ones you have in the US?
First thread for me
