codered
- Aug 18, 2014
- 9,502
- 2,152
- Location
- in da ghetto, FL
- 1998 QCSB
- magnum 5.9/360
I can push the gas pedal up with literally no effort. Can anyone tell me how to fix this thank you.
I might go inspect behind the pedal to see if anything is wrong. It has great response just worried a bit cause it has playshould not take too much effort to push the gas all the way down. sounds normal. new cars are even worse.
Do tell. And my throttle cable is way out there my pedal has 1 inch before it hits the ground.if there is slack in the line that is a bit different than being able to push the gas pedal easy. new cars take no effort at all to push the gas which kills my ankle. you can possibly do the zip tie mod to get the slack out of the cable. it is a real simple mod.
...but if there it too much slack it would probably be a better idea to just replace the throttle cable.
Hell, I might do one. xD
I did it, put one zip tie on mine and it worked great.
Damn, that's worse than mine. lol Might need two then.I know I have about a good 2-3 inches of cable coming out of the firewall
like i said, very surprised there was not one here when i looked. i know it is old news on the old forum that we use to hang out on.
probably 3 I just need to seeDamn, that's worse than mine. lol Might need two then.
Yeah, I never gave it much thought.
